2 cycle engine
Old 07-30-03, 07:53 PM
sniper3270
tanaka weedeater
I have a tanaka weedeater tbc-215 model number c157131 my question is what is the high side setting on it?? it runs ok if i get it idle good it doesn't run well if i get it to run well it won't idle it may be the carb. ................need help THANKS
Old 07-31-03, 12:04 AM
cheese's Avatar
Hello Sniper!
Sounds like you need a carb cleaning and possibly a carb kit. Generally, you can get a base setting by turning both screws in until they lightly bottom out, then back out the low screw 1 to 1.5 turns, and the high screw out 2 to 2.5 turns.
Old 07-31-03, 07:52 AM
sniper3270
2 cycle engine
thanks for the help i have cleaned the carb out but didn't know the settings for the screws but it's still a posabilty it needs a rebuild it is a walbro carb. is that still the basic settings for the screws low 1- 1.5 and the high 2- 2.5 from lighty seated?...................thanks for the help.
Old 07-31-03, 09:46 PM
cheese's Avatar
Yep, start with that, then fine tune from there.
