chainsaws
Old 08-20-03, 09:38 PM
boman's Avatar
chainsaws
Why is it some chainsaws will go right through rough vines and brush and some will slip the chain?
I have a Craftsman that slips the chain when trying to cut brush, vines ,etc. even with a new chain. It cuts logs pretty well. I also have a Poulan Pro the will cut right through this roughage but does not cut trees very well. Actually the Poulan cuts trees as if the chain is a little dull, and I guess it is. Do I need to check the bar on the Craftsman to see why the chain tends to come off when trying to clear brush and vines?
Old 08-21-03, 01:43 AM
cheese's Avatar
Received 141 Upvotes on 130 Posts
Brush and vines give so much when the chain bites them, and then they twist and bind and apply uneven pressure to the chain. If the bar is worn, it will contribute to the problem. Cutting small stuff like this can cause the saw to grab and snatch, so be careful. If the chain catches a vine or other material on the top side of the bar, it can really shove the saw straight back at you before you know what happened.
