Engine Oil Consumption
woodhill's Avatar
08-25-03, 11:52 AM   #1
woodhill
kohler blowing oil out carb/help please
thanks in advacne for all responding
I have a cub cadet riding mower with a kohler 4 cycle engine
family skk162441g2ra
model ch18s
624cc
serial #2604600757
has in excess of 700 hours for the last mowing season I have been using quaker state synthetic oil, now I am noticing oil consumtion and blowing out the carb into the breather
any ideas......mow 3 acres at a time
new here so saying thanks for a forum like this again
woodhill
cheese's Avatar
GA
08-25-03, 10:23 PM   #2
Hello Woodhill!
Welcome to the small engines forum at DIY!
What weight oil are you using? Is the oil level overfull? Those things can help determine the cause of the problem. It could also be a restricted air filter, blown head gasket, pinched breather hose, engine wear.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Terminator20's Avatar
08-25-03, 11:14 PM   #3
Its probably most likely that the engine has to much oil in it past the recomended limit.
woodhill's Avatar
08-26-03, 05:37 PM   #4
woodhill
reply to oil squrting
thanks for the response ,,,,, oil level is correct using quaker state synthetic 5w20 as per specs.....my thought are a rign bad or crack in piston ??????
how do I check for these??
08-26-03, 06:43 PM   #5
You have to take the engine completely apart to check for a crack in the pisten. But, I don't see how a cracked pisten would blow oil out of the carb.
cheese's Avatar
GA
08-26-03, 11:36 PM   #6
Are you sure the manual reccomends 5W-20? That should only be used in extreme cold temperatures...if ever. That is too thin. I would drain it and put in straight SAE 30w. If you look, I think you will find that the only time a multi-weight oil is reccomended is when the temps are quite cold. Some manufacturers even state that use of 10w30 oil will result in oil burning. There are problems with using multi-weight oil in small engines, as the viscosity index improvers do not fare well in the heat of an air cooled engine. The oil reverts to a 5 weight oil before long, and that is definitely thin enough to cause some smoke. Try that first. I doubt a cracked piston is your problem, but that would definitely let oil blow into the carb, as would a bad ring, blown head gasket, scored cylinder wall, pinched breather hose, etc...
God bless!
