Engine Running Problem
Old 08-24-03, 12:41 PM
eazyyy
Toro 6.5hp Model 20016 will not stay running
Hello: Just got this yesterday, it is the high wheel, self propelled. Problem: Will not run when hot, about 3 to 5 minutes after starting. Tecumseh LEV 80-120 without choke and with primer bulb. Have checked linkage, fuel, oil and rubber lines (moved rubber gas line from next to engine, though it might be a vapor lock. no improvement).
Any help appreciated. Thank you
Emory Zimmerman, repairman@intergate.com
Old 08-24-03, 03:30 PM
Terminator20's Avatar
Please give us the make of your mower and your model number so we may further help you.
Old 08-24-03, 03:37 PM
eazyyy
Hello: What you asked for is in the subjexct line, I think.
Toro Model 20016 6.5 hp
Thank you for the reply.
Emory
Old 08-24-03, 06:36 PM
Tcumcman
Toro 20016 LEV120
Eazyyy,
If the mower will start after priming and only runs for a
few seconds....indicates a "restriction" in the main fuel
jet (which is in the bowl nut), OR....you possibly have
water in your fuel. Remove bowl nut, look for the very
small orifice/hole in the upper tapered side of the nut.
Clean with a small piece of stiff wire, and replace. Try
priming and running again. If this doesn't help....try
NEW, FRESH fuel. Best of luck !! I own a 20017 with SAME
engine and have been VERY PLEASED thus far.
Tcumcman
Old 08-24-03, 06:55 PM
I would agree with what he said. Do that and let us know how it goes.
Old 08-24-03, 08:53 PM
cheese's Avatar
Received 97 Votes on 90 Posts
Hello eazyyy!
Welcome to the small engines forum!
Tcumcman has given you some good advice. One other less likely possibility could be that the gas tank vent is restricted. Try loosening the cap when it starts to die out and see if it picks back up again.
Let us know how it goes!
Old 08-26-03, 01:36 PM
eazyyy
On that Toro that would not stay running.
I replaced bot the coil and the gas cap. I do not know which was the problem, but it works like a horse and drags me along behind it.
Thank all of you for your help.
Emory
Old 08-26-03, 11:55 PM
cheese's Avatar
Hi Emory!
I merged this thread into your old one, so that it would all be visible at one time.
Glad you got it going! I'm kinda wondering why I didn't mention a coil here. It was kinda obvious. Oh well...at least you got it !
