magneto problems
Old 09-13-03, 01:18 PM
b88bsr
magneto problems
I have a toro 6HP push mower that was giving me problems when starting it. I cleaned the air filter, carb, replaced the plug and still wont start. My neighboor noticed that the magneto was somewhat rusty so I took it off and wire brushed it clean. I also rotated the ??? ( the thing the magneto almost rubs against) and wire brushed the rust off of it.
I've put everything back together leaving about a credit card's clearance between the magneto and the whatever it's called. I still cant get it to start.
I'm wondering if since I turned the engine manually a few times, is there some sort of timing marks that have to be alighned to get it to fire up correctly?
Old 09-13-03, 06:54 PM
Terminator20's Avatar
First question I have is, are you getting spark?
Second question I have, is there fresh gas in the tank?
Third question I have is, is the starter moter cranking the engine?
Old 09-14-03, 02:22 AM
cheese's Avatar
Received 97 Votes on 90 Posts
Hello b88bsr!
Those are 3 good questions by terminator. A credit card is too thick...try a business card. There is nothing to be messed up by turning the flywheel. There is a key that holds the flywheel in place on the crankshaft though, and if something is hit hard enough, it will shear that key and affect the timing.
Old 09-19-03, 06:15 PM
b88bsr
Fresh gas - Yes
Spark - No
Starter motor - Not equiped
I've moved the magneto in closer and still no spark.
Shear pin is intact and straight.
Old 09-19-03, 11:06 PM
cheese's Avatar
Is the safety bar cable fully disengaging the blade brake and kill switch? Remove the kill wire from the coil and check for spark.
