Honda OHC Timing procedure
Old 09-28-03, 12:24 AM
twross
I am repainig a Honda 5.5 Hp OHC engine model #GJAF and need to know how to set the timing.Any information would greatly be appriciated.
Thank You
Thomas Ross
Old 09-28-03, 11:33 PM
cheese's Avatar
Received 142 Upvotes on 131 Posts
Hello twross!
Welcome to the small engines forum!
Camshaft timing? I assume that's what you mean?
Old 10-02-03, 09:38 PM
twross
honda cam timing
I was refuring to the cam timing, I was able to figure it out, I found that if I placed the crank at TDC there was an arrow that lined up with a notch in the rod and a line on the block and I found that if i also placed the cam at TDC there were two marks on it that lined up with with the valve cover gasket surface.I have ran the engine and it seems to be running ok, if this is not the correct timing positions please let me know.
Thanks
Thomas Ross
Old 10-02-03, 11:20 PM
cheese's Avatar
Sounds like you got it right. Glad you got it going!
