Homelite Chainsaw
Willyp's Avatar
10-03-03, 01:15 PM   #1
Willyp
Homelite Chainsaw
I accquired an older Homelite 550 Chain saw that hasn't run in over ten years. It seemed to run fine for a couple minutes and then stalled and i couldn't get it started again. So i started messing around with it an started turning all the little knobs. So to get it started i had to spray starter fluid in the air intatake. i t took off But it didn't idle and if i let the trigger out it would run faster and if i pulled the trigger it would slow down. Also if i turn the choke off it takes of to full rpm no matter where the trigger is at. So im sure i need to adjust the carbuerator there are two screws, one on top of the other i didn't really feel like adjusting them by trial and error since there is a chain spinning really fast close by so if anyone could give me a starting point that would be great. PS. During this operation i had the air filter offf if that matters a whole bunch. Thanks
Terminator20's Avatar
10-03-03, 03:09 PM   #2
Before adjusting the carb, I would clean it out first. Do a good job too. Carbs can be tempurmental if there not cleaned well. Another thing I would do is buy an new spark plug. And the last thing I would do is dump old gass out and install fresh gas in gas tank. Cheese will reply to your message soon enough. Let us know how it goes.
cheese's Avatar
GA
10-04-03, 12:15 AM   #3
Hello Willyp!
I would first suggest purchasing a rebuild kit for the carburetor and new fuel lines. Surely after more than 10 years, these things need to be done. I doubt you will get far without doing it. I assume the gas you put in was fresh, since 10 year old gas won't even run in a saw, but you definitely want a clean tank of gas, and a new plug would be wise as Terminator mentioned.
Let us know if we can help!
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
