lawn mower engine
Old 10-06-03, 04:42 PM
chrisarn99
lawn mower engine
I have a techumseh 7 horse engine. I put in a connecting rod. I want to time the cam shaft. It has a scribe on a v between teeth, but no match on the cranksaft gear. any help? maybe to a website that could help? Thanks
Old 10-06-03, 10:39 PM
cheese's Avatar
Hello chrisarn99!
If the crankshaft gear is held on by a key, the tooth in line with the keyway is the tooth to line up with your cam mark. If the crankshaft gear is pressed on, there should be one tooth that has a bevel to serve as a timing mark.
Hope that helps!
Old 10-15-03, 06:37 PM
Terminator20's Avatar
Did you ever figure it out?
Trackbacks are On
Pingbacks are On
Refbacks are On
