lawnmower belts
lawnmower belts
Dear sir
My question is regarding snapper belts.Iam replacing the deck belt on a snapper lawn tractor model LT160H42CBV2.The problem i have ran into is The original belt is 103 inchs long.The replacement belt is about 100 inchs long.The number for this belt is 2-9205.Iam needing to know if snapper makes a belt that is 103 inchs long so i can replace it.In my owners manual there is a belt number 2-8582 for tractor model LT160H42CBV.Is it possible that snapper has the two numbers switched.Looking forward to your reply.Thanks alot mowerman.
I agree...there seems to be some problem like maybe a mis-labelled belt, or a misprint. From what I can tell, you have a 16hp 42" cut mower...tractor style. You shouldn't have any problem getting the right belt for it. Explain the situation to the place you got the belt from. Are they selling you an original equipment belt, or aftermarket?
