chainsaw
k8dxe's Avatar
11-04-03, 02:21 PM   #1
k8dxe
chainsaw
Mac 3200 chainsaw, I replaced the fuel lines and am not
sure if they are right. I have them run from tank to primer ball
to the pump side of the carb. other side carb. over flow tank. I pump the ball and pull 3 or 4 times it run for 5-10 sec.
Dick
needles's Avatar
11-04-03, 04:01 PM   #2
needles
It's only getting enough fuel to run for that 10 seconds,you must of mixed up a host,so the only fuel it gets is when you prime it.
k8dxe's Avatar
11-04-03, 05:06 PM   #3
k8dxe
Thanks for your replay. any hints on how the hoses should run.
cheese's Avatar
GA
11-05-03, 01:11 AM   #4
Hello k8dxe!
The primer outlet should pump fuel into the tank, the suction side should be connected to the carb overflow, and the fuel supply line from the tank should connect to the carb supply.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
k8dxe's Avatar
11-05-03, 04:53 AM   #5
k8dxe
Thanks you guys sounds good to me.
Dick
