Solenoid problem
Old 11-11-03, 01:05 PM
Solenoid problem
Have a Mtd. garden tractor with a Briggs 18.5 HP engine. Starter has only been turning over the engine sporadically. Most of the time when you turn the ignition to start, nothing happens. Solenoid has three terminals on it, one from +battery, one to starter, and last is a small gauge wire to ignition switch. If I disconnect this small wire from the solenoid and attach a volt meter to it, it will read 12 volts when I turn the ignition switch to start. However, when I reconnect it to the solenoid and try to read voltage I get zero.
Jumping from battery+ direct to this same terminal will turn the starter as it should.
What's my next step?
Thanks for your help.
Old 11-11-03, 02:00 PM
Terminator20's Avatar
If I were you I would replace this small gage wire. Most likely that wire is worn out. I have noticed through experience that small gage wire does not last as long as battery terminal wires. But, cheese will be here to give you a second opinion.
Old 11-11-03, 06:03 PM
Thank you Terminator,
I should have mentioned that when I jumper between the ignition switch and the solenoid the same thing happens. It worked well for a few times and then nothing. Reads 12 volts with ignition turned to start when not connected to the solenoid and no reading when connected.
Old 11-11-03, 11:43 PM
cheese's Avatar
Hello msabot!
What you are describing sounds exactly like a bad ignition switch terminal. Unplug the switch and look at the main power terminal. I bet it is rusted up pretty bad. Clean the rust off and try again. Let us know what you find!
Old 11-19-03, 07:54 AM
Thanks Cheese!
Your idea about the ignition switch "hit the nail on the head". The terminal was so corroded that it could not be cleaned so I replaced the switch and all-is-well. Thanks again.
Old 11-19-03, 09:20 AM
Great Job!!!
Old 11-19-03, 10:56 PM
cheese's Avatar
Glad we could help! Thanks for letting us know how it went!
