No spark at plug
Old 11-16-03, 06:48 PM
alpal
No spark at plug
The engine cut out and I found no power coming to the spark plug..Briggs and Stratton Model:110908....Type.1201-01...Code..82062404..Is there an online manual for this model?..
Old 11-16-03, 07:14 PM
mower17's Avatar
If when you hold the spark plug wire really close to the block there is no spark, then disconnect the kill wire that is plugged into the side of the coil and try again. If you then get a spark, then it's the coil. If you do get spark, then the kill wire is the problem. Or as FISH said, it could be dirty or burnt points.
Old 11-16-03, 07:16 PM
Fisher
Did the engine just die, or did you hit something. Has anyone
done any work on the mower just before it stopped running?
Your engine has points, so that is a likely place to start.
Fish
Old 11-17-03, 12:47 AM
alpal
No spark at the plug...
Thanks guys it was the kill wire it must have got caught up when I was pushing the mower under some branches....
