Tecumseh Diaphragm Carb
Old 11-19-03, 07:12 PM
fabe317
Greets
I have a small Toro Sno-Blowr that I want to install a new diaphragm in the carb and I can't remember which way I took the old one out
Does the round 1 inch diameter metal plate in the center of the diaphragm face in or out away from the needle valve?
Engine tag # is 7829884 preceded by 1574B
Regards
Old 11-19-03, 10:38 PM
cheese's Avatar
Received 56 Votes on 51 Posts
Hello Fabe317!
The head of the rivet that holds the disk on goes toward the needle. I believe this means the disk goes toward the needle, but it's been quite a while since I messed with one of these carbs.
Old 11-20-03, 06:47 AM
fabe317
Thanx fer yer reply cheese
I'm still unsure - the head of the rivet and the disk itself seem to be opposite sides
I hav now resized the photo to stay within the forum
guidelines but see no way to re-add it
Attached is a photo of opposite sides of my old and new diaphragm
Regards
fabe
Old 11-20-03, 01:23 PM
fabe317
Had to reply to my own post in order to get the photo added on
Regards
fabe
Old 11-20-03, 03:35 PM
fabe317
I'm working on my Toro 2 stroke snowblower carb right now.
My diaphragm has a large disk on the rivet heat side and a small washer on the side that is peened.
The side with the rivet head would go against the needle, thats the one with the large disk
Larry
Old 11-20-03, 09:47 PM
cheese's Avatar
That's what I thought...just hadn't looked at one in a while. The head should be the smooth rounded end of the rivet. It should be on the side with the disk according to Larry , and my vague memory. To post a pic on this site, you have to post your pic elsewhere on the web and link to it on this site.
