toro 521 snowblower
toro 521 snowblower
I have an older Toro 521 snowblower. I need to replace the auger drive blet but am unsure how it is removed. I have taken off the tension pulley but there is not enough slack to take it over the main pulley. Anyone taken one of these apart?
Hello sabrefan!
I have no experience with snowblowers, as we don't get to see them in S. GA., but here is an idea....If there is an idler pulley that is just bolted in place, remove it to allow slack in the belt. Also, if the belt is loose enough, you can pull it over away from the pulley while you rotate the pulley and belt. This will "roll" the belt off.
