12-08-03, 09:05 AM
saugusta
Tecumsah snow blower engine running rough
I have a Troy-Bilt snowthrower with an 8HP Tecumseh Snow King engine. The engine is running very rough - surging from very high RPM, down to where it just
about cuts out. It's also consuming a LOT of fuel. When the auger is engaged the RPM drops significantly, but this doesn't happen when the wheels are engaged. I've tried replacing the spark plug and have changed the fuel. Any other hints from the forum?
CAL
12-08-03, 06:17 PM
Hello saugusta. Welcome to the Do-It-Yourself Web Site and our Small Engine forum.
Based on the problem description, the engine is flooding from too much fuel. There should be some black smoke visable from the exhaust. If that is correct, the carb needs to be cleaned out and a new carb kit installed.
If such is not the case, chances are the carb is not allowing enough fuel causing a lack of fuel to get into the engine. That will cause the engine to bog down under a load and or stall or die.
Reading any existing question which indicates an engine running problem, you will find additonal helpful advice, suggestions, including solutions to correct the problem.
Most likely I haven't covered all of the possibilities. The other resident small engine service and repair professionals in the forum may be able to offer additional suggestions, advice & help.
Check back on your question several times over the next few days for additional replies.
Small engine repair parts, generic repair manuals and additional help are all available at all local small engine repair shops and or lawn mower repair shops in your area. Shops and dealers are listed in the phone book directory.
Suggestion:
Read all already asked questions and the replies offered in them on this same type of problem for additional help & information. Doing so will provide additional possible causes and the solutions to correct them.
If you need further assistance, use the REPLY button. Using the reply button moves the topic back up to the top of the daily topic list automatically & keeps all communications in this one thread.
Regards & Good Luck. Sharp Advice.
Small Engine Forum Moderator. Web Site Host, Forums Monitor and Multiple Topics Moderator.
Small Engine Diagnostics Services & Repair.
"Accurate Power Equipment Company."
Fast...Fair...Friendly & Highly Proficient Services....
Suggestion:
GA
12-08-03, 09:39 PM
Hello saugusta!
I agree...you have carburetor problems. If it is flooding, make sure the choke is not closing, make sure the float is not full of gas, and check the carb adjustments. It may also be leaning out. If so, remove the float bowl and clean the bowl and the bowl nut...(it should have tiny holes in it that could be clogged).
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
