Snowblower kind of works...
Old 12-12-03, 02:54 PM
s_ginter
Need a little advice.
I got a Sears Craftsman blower for free. It had an 8hp Tecumseh that was blown, hence the price. I got a shop manual and a used 10hp shortblock, put it together again, including a new auger bearing kit and new belts. It throws snow, but not really well. Could I have the maximum engine speed too low? I'm pretty sure I've got enough tension on the auger pulley, as it tries to spin in neutral. The pullies were a little rusty, so I cleaned them up before the new belts went on.
Any ideas appreciated
Thanks
Steve
Old 12-13-03, 12:07 AM
cheese's Avatar
Received 56 Votes on 51 Posts
Hello Steve!
What RPM is the engine running at full throttle?
Old 12-13-03, 04:05 AM
s_ginter
3200-3250
Old 12-14-03, 08:35 PM
cheese's Avatar
Sounds about right. You might need to clean or adjust the carburetor. If it has a small screw under the bowl, try backing it out 1/4 or 1/2 turn and see if that gets your power back.
