Tecumseh 10hp Snowblower
Old 12-10-03, 06:20 PM
shortie
tecumseh 10hp snowblower
I committed the seasonal storage of a small engine sin.
I didn't drain gas from tank or bowl, consequently my
craftsman snowblower won't start. added a sqirt of gas
to carb and it would start but stop as soon as gas use up.
intend instaling carb kit.
any suggestions? anyone know a rule of thumb for setting
idle mixture screw and main adj screw or anything else
i should know befor i try to replace these screws, intend
replacing float as well. need help
thanks in advance
Old 12-10-03, 08:22 PM
cheese's Avatar
Received 56 Votes on 51 Posts
Hello Shortie!
You probably will do just fine if you remove the float bowl and clean it out, and clean out the tiny holes in the bolt that holds the bowl on. You might not have to replace anything...check it and see.
Old 12-10-03, 08:23 PM
Terminator20's Avatar
Clean your carberator really well. You should be able to get it running after that. Make sure you are getting spark as well.
Old 12-12-03, 07:13 PM
shortie
Smile Tecumseh 10hp Snowblower
I did the carb kit thing and the snowblower wouldn't start.
adjusted the bottom screw at the same time trying to start
it with electric starter, low and behold, it started and runs well
when I shut if off a slight blue flame came out of the muffler.
thanks for your confidence cheese and terminator20.
i'm usually good as a diy but this is the first time i tried a carb.
i was always scared of the settings and adjustments.
Any with the motor purring I tried to shift from reverse to forward
no go., does this mean my transmission is siezed. I disconnected
the linkage and tried to shift gears by hand near the back of the engine, no go.
WHAT do I do guys. Is there a transmission fluid filling or testing
valve/nut i can get at or add fluid or what . appreciate any help
as i'm one proud diy after it starting when i did the carb cleaning,
but still would like to go forward with this snowblower
Old 12-13-03, 12:03 AM
cheese's Avatar
Glad you got it going!
Have you checked your drive belt? Make sure it's on...sounds like it is either off, or not engaging.
I merged this thread with your old one to help us keep all info in one place for easier reading/following the progress of the project.
You can use the reply button instead of the "ask a new question" button at the end of this thread to add new info or questions.
Old 12-14-03, 08:03 AM
shortie
snowblower drive/gears
ref my going forward with snowblower.
gears in reverse, can't move the handle it is stuck or siezed.
does the engine have to be going to shift from reverse
to forward gears.
i have all cover plates off and blower resting on chute
can't see anything wrong. both drive belt and auger belt
on. just cant seem to move gears. i disconnected the linkage
in case it was the actual linkage, and tried to move the gear
by hand. nothing moves. all springs etc seem ok
confused, can u help, also the cogged wheels with chains
on are very rusty should i do any extra maintenance
while i have it a part. thanks
Old 12-14-03, 08:07 PM
cheese's Avatar
Sorry I have no idea what compnents make up a snowblower transmission. I live too far south for snowblowers. Try lubricating the areas that move when shifting. Try rotaing the transmission input shaft as you put pressure on the shifter and see if it will allow a shift.
Old 12-16-03, 06:37 PM
shortie
Question snowblower-forward gears
My craftsman 10 hp dual stage snow blower mod
c950-52530-6 is still giving me trouble. It is in reverse
gear and I can't get it to shift to forward gears. Any other
suggestions in getting this machine to go forward.
Old 12-16-03, 10:10 PM
cheese's Avatar
I was hoping to be able to see this on the sears website, but they don't recognize that model#. Wish I could be of more help.
Old 12-17-03, 12:56 PM
jlm
If your drive system has a rubber disc that runs against a aluminum plate, the slide system is rusted. Lubricate all the shafts in the drive and work the disc back and forth with a pry bar of some sort. Be sure the rubber wheel is moving up off the plate when you try to shift. Once you break it free and lube under where it was stuck it should be fine.
Hope this works for you!
Old 12-17-03, 06:01 PM
shortie
10 hp snowblower forward gears
let it snow, let it snow, shorti's snow blower can now
go forward and backwards. jim you were right on the money
the clutch was seized to the hex shaft like you said, i use
wd40 into the clutch and around the shaft and use bar and
hammer to loosen it and presto the clutch just slid along
the hex shaft. I connected the linkage back up and it works
fine, now to get everyting back to together.
note: i certainly will do the proper maintenance when i put
it away after this winter. Thanks again Jim and Cheese
your advice did the trick.
Old 12-17-03, 07:08 PM
cheese's Avatar
Great! Glad you got it fixed! Good call jlm!
Old 12-18-03, 06:10 AM
jlm
Thanks Cheese! I'm located in Connecticut so I've seen a snowblower or two in my time. Unlike your location we get a lot of snow here.
Old 12-19-03, 01:38 AM
cheese's Avatar
Hmmm...I don't envy you, lol. I like warm weather .
Old 12-19-03, 05:10 PM
shortie
recoil starter cord
got it working ok, instaling a new starter cord that is.
The first time I tried it I didn't know to wind up the recoil spring
then feed the new cord in. I did wind it up but not enough so
when I tried to start it the cord only half recoiled. Then cheese,
I remembered you saying feed the cord in and let it rewind, so i wound it up all the way, fed the cord in, knoted it like you said
and put it back on the blower and presto she started off first
shot. This cord was broken since last year, didn't believe it was
that easy to replace. Thanks again Cheese and to jlm I'm just
waiting for the snow to come(if you build it (snowblower) they (flakes) will come,
Old 12-19-03, 09:50 PM
cheese's Avatar
Good job! Thanks for letting us know how it turned out, and glad we could help!
