snowblower no cold start
Hello, my White snowblower with 9HP Tecumsah engine starts first pull and runs fine when it is "warm" outside e.g. 45F, or after being in my basement overnight, but doesn't even sputter and try to start when it is stored cold (outdoors). This isn't very convenient, since it never seems to snow here in warm weather.
Once running, it will start again, first pull, regardless of temperature.
This is true with both the hand and electric starter.
Any ideas? Thanks,
Any ideas? Thanks,
I don't know if the choke is failing when outside-cold. It does work when the snowblower is warm enough to start- I need to "unchoke" almost immediately to even it out.
I'll be away from my computer for the next week, but I still appreciate any help that is posted.
Thanks,
Thanks,
Hello Greg!
I agree with Mower17. Check the choke...look at it visually, inside the carb throat. Make sure it is closing fully. Also make sure the throttle is set to full speed when trying to start it.
If your plug is getting sooted by gas, take a look at the air filter to be sure it isn't clogged, make sure the choke is opening fully, and if no problems are found there, carb adjustments may need to be made.
gregl
The spark plug will tell sooooo much about how your engine is running. The black coating on the plug is usually an indication of a "too rich" mixture. or a very weak spark which won't burn the fuel completely. Plus you said that when you replaced it, it started up but it seemed you couldn't release the choke enough.
I would check out the High Speed adjusting screw(located on the bottom of the float bowl) and lean it out (turn cw) just a bit. This is done after the motor has been running for a few minutes and is up to operating temp and is at full throttle.If this doesn't produce the required results you may want to check out a rebuilding of the carb. The reason I'm going with the carb rebuild instead of looking at the ignition is because the gas nowadays just doesn't stay fresh long enough and that is the majority of the headache causes.
On a snowblower there is no air filter just a cover (not much dust in the winter) and that's for keeping some of the heat in so the carb won't freeze up.
One other thing and I recommend this "highly" is purchase a Tecumseh repair manual for your motor from your local small motor dealer. These are the most invaluable tools that you will ever have.
Hope this helps
snoman
Hope this helps
snoman
Ahh yes, I did know that there are not air filters on snowblowers, but I keep forgetting we're talking about snowblowers here. Snoman is right, if you do not find any problems with the choke staying closed, you may just need to adjust the high speed mixture screw.
