Carburetor Question
meach's Avatar
01-05-04, 10:43 AM   #1
meach
3.5 HP Tecumseh Carb(Montgomery Ward Snow Blower)
I have a Montgomery Ward Snow Blower with a 3.5 Hp Tecumseh engine. However it is missing the Carb. The intake tube is there. Im not sure of the year, I'd guess late 80's. Can anyone tell me what carb will work for it?
Thanks in advance, Meach
chfite's Avatar
SC
01-05-04, 11:09 AM   #2
move post
I am going to move this to small engines where you will find more assistance.
snoman's Avatar
CANADA
01-05-04, 03:10 PM   #3
meach
On the starter housing there will be a series of numbers, these are the model, type, and serial number.eg h35-55123 ser #### If you can give them to me I can see if I can find the replacement required for your particular motor.
Or you can go with trying to find a used one from a motor around the same horsepower. The usual differences are the choke lever setup and sometimes but not always the throttle lever setup. Also you will want to make sure the throat of the carb is the same size. I believe that a carb from a 4 hp may work (I just did a swap on the same type of motor earlier last week)
snoman
