Tecumseh H70 Snowblower won't run
Old 01-22-04, 01:41 AM
hunter
I have a Snow King 8hp Tecumseh snowblower. The model number is H70. I have put new points,condenser,and plug in it. The Carberator has new needle,seat,and float. The engine will idle nicely , but when i open the throttle it starts to choke itself out. It spits black smoke and hardly runs when the throttle is opened. Any suggestions?
Old 01-22-04, 02:18 AM
jughead's Avatar
It sure sounds like the engine is running rich. Make sure the choke is off. If it is then try adjusting the high speed mixture control on the bottom of the carb. It should be adjusted in by turning the screw to the right. You may not have to turn it much. Maybe only a half a turn or so. If that doesn't do anything for you the screw can always be moved back to the origional position.
Old 01-27-04, 08:49 PM
pops64
Rich running and smoke can also be a dirty air filter. Have you cleaned or replaced it recently?
Old 01-28-04, 01:50 AM
jughead's Avatar
Usually snow blowers don't have air filters. Mine doesn't (with a Tecumseh engine) so if you don't find one don't waste a lot of time looking for it.
Old 01-28-04, 03:05 PM
tidajo
Tecumseh carb
i found the Tecumseh tec manual online. can view or print.
http://www.cpdonline.com/692509.pdf
Should find your answer there.
Old 01-28-04, 07:06 PM
snoman's Avatar
tidajo
That is one awesome site for reference...that's gonna help alot of people here.
snoman
Old 02-05-10, 11:15 PM
Guy Marchaud's Avatar
Another Source
This link no longer seems to work. Did anyone download the H70 manual and would be willing to share a copy? Thanks.
Old 02-06-10, 04:17 AM
5dollaralien's Avatar
The link worked for me. I can try to send you a copy
Old 02-06-10, 06:35 AM
It's 2.5M so it takes a while to download. It worked for me this morning.
Old 02-06-10, 06:37 PM
when you get the manual you may find that changing the points requires re-timing the engine. You did have the specs for gapping the points
Trackbacks are On
Pingbacks are On
Refbacks are On
