01-23-04, 01:06 PM
scamper
Hi,I'm back again, my snowthrower MTD 5/22 with Tecumseh Hssk50 engine didn't have a fuel filter installed, would it be to my advantage or disadvantage to install a inline filter?
01-23-04, 01:42 PM
I don't think you can go wrong filtering your fuel. However Snow Blowers operate in an environment such that if the filter traps moisture it will freeze and the engine won't run. Similar explanation as to why Snow Blower engines don't have air filters. They would trap moisture and clog with ice.
Some guys have been reporting the use of a funnel that has a an integral fuel filter moisture trap.
Marc
Marc
01-23-04, 04:08 PM
scamper
Thanks
scamper
01-25-04, 08:08 PM
If snow is coming at you when its blown out than the answer is obvious. Blow the snow the other direction so snow does not accumilate on the machine and yourself.
01-25-04, 11:19 PM
scamper
HI cheese, thanks for the reply, you don't think a filter would restrict the amount of fuel required to run this thing do you? I can't help to wonder why they never installed one.
Thanks
scamper
Thanks
scamper
GA
01-25-04, 11:27 PM
No, it shouldn't restrict the flow at all. It will be fine with a filter. I suppose it didn't come with one for either cost factors, and/or the fact that snowblowing isn't a dirty/dusty operation, so contamination wouldn't be such a problem. (like cutting grass would be).
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
02-01-04, 09:57 PM
pagerboy
Originally posted by Terminator20Yeah right, tell mother nature to turn the wind off.
