Briggs engine
Tools's Avatar
02-08-04, 05:51 AM   #1
Tools
Briggs engine
Have an older 8 HP Briggs engine-1978 with 50 hrs running time on it,has a recoil start,is it possable to get a flywheel with a ring gear on it to put on this engine?
snoman's Avatar
CANADA
02-08-04, 08:40 AM   #2
tools
Get your model number,type and serial number off the starter shroud and go to you local small engine dealer. They may be able to reference a flywheel for that particular motor through the Briggs book.
snoman
cheese's Avatar
GA
02-08-04, 10:26 PM   #3
Hello Tools!
You should be able to find a good used flywheel with ring gear for it at most any small engine repair shop. You'll also need the alternator that bolts under the flywheel for charging the battery.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
rogerh's Avatar
02-11-04, 07:29 PM   #4
Tool;
Get the model number off the shroud and go to the link below. They have a lot of information if you can find it.
www.briggsandstratton.com
Good luck.
Roger
fordv10f1's Avatar
02-12-04, 07:56 PM   #5
fordv10f1
If you find out what you need try ebay. New flywheels are very expensive and used ones at dealers are half that much. Good luck and make sure you have alternator mounting screws in the block!
Got horsepower? I do! Turbocharge it!
