1983 craftsman varidrive lawn tractor
Old 02-25-04, 06:10 PM
chev1986
Looking for the schematics for the belts on the 1983 craftsman varidrive lawn tractor. Not sure of the routing of the belts.
Old 02-25-04, 06:30 PM
cheese's Avatar
Received 55 Votes on 50 Posts
Hello chev1986!
Take a look on www.sears.com/partsdirect . Punch in the model# and view the diagram for the belts. The mower might be too old to be in their database. If so, try a small engine shop, or contact sears for a manual.
Old 02-25-04, 06:34 PM
chev1986
Hi to you Cheese
Thank you for the info. Just trying to fix up an old tractor all help greatly appreciated.
God Bless
Old 02-25-04, 09:50 PM
cheese's Avatar
I just remembered I think I have one of those old varidrive sears mowers at the shop...been tucked away at the back fence for a couple years. If you can't find the info you need, let me know and I'll look at the mower I have and see if I can describe the belt setup to you.
Old 02-29-04, 05:57 PM
chev1986
I have looked and theyare telling me that it is so old that I can't even get the owners manuel anylonger. If you would not mind I would be eternaly greatful if you could send me something showing me the routing. my e-mail is scooby_6162000@yahoo.com . Again thank you for all the info and God Bless
Old 03-03-04, 12:57 AM
cheese's Avatar
Sorry I haven't gotten back to you sooner. My modem went bad, and I couldn't get online for a bit. I'll go look at the mower and see if it's a varidrive and let you know what I find out.
Old 03-03-04, 04:40 AM
chev1986
I am very greatful for your kindeness. I appreciate all that you have done already .
God bless
Old 03-03-04, 10:33 PM
cheese's Avatar
Ok...the primary drive belt goes from the engine to the varidrive pulley. It runs from the top engine pulley (pulley closest to the bottom of the engine), along the right side of the mower, on the outside of the first small pulley connected to the clutch, then to the inside of the second small pulley connected to the clutch. These small pulleys are along the right side of the underside of the mower. The first one is a V groove pulley and the v of the belt contacts the pulley. The second one has a flat surface. The flat side of the belt contacts this pulley. Then the belt goes back to the top pulley on the varidrive. The secondary drive belt just goes from the bottom pulley on the varidrive to the transaxle pulley. Hope that is clear enough. Let me know if you need more info!
Old 03-05-04, 04:23 AM
chev1986
You have a been a wonderful help thank you again. I truely appreciate all the effort you put into helping get this thing up and running again. God Bless you and yours
Old 03-08-04, 12:32 AM
cheese's Avatar
Anytime! Did you get it fixed?
