Lawn mower tires?
Lawn mower tires?
I have a Zero turn Toro that came equipped with Kenda Super Turf tires. Size is 18x6.50x8. I'd like buy the tire that has the best traction on grass. Do you have any idea which ones I should be buying?
Thanks for your help in advance.
Hello Performin Norman!
Regular turf tread tires provide good traction with little damage to the grass.
try www.belairturf.com or cartparts.com.
generally speaking the more aggressive the tread the better the traction but thr harder it is on the turf. there are several tread pattern avalable from smooth to ribbed to knobby. we use the turf tread with the rounded edge on our general purpose rotary mowers, and the slick tread on our greens mowers.
