Briggs leaking gas
Old 04-06-04, 08:31 PM
michaelshortt's Avatar
Briggs leaking gas
Have a Campbell Hausfeld Press cleaner with a Briggs and Strattion OHV 190 cc engine. Runs great, except after using the fuel leaks from inside the carb until the tank is empty. Sound lie the needle and seat leaking?
Old 04-06-04, 11:31 PM
cheese's Avatar
Received 22 Votes on 19 Posts
Hello Mike!
You got it! Pull the bowl off and see what's in there. Could just be some trash floating around in the bowl causing the needle to leak. A bad float will also cause this.
Old 04-11-04, 09:13 PM
Terminator20's Avatar
How did it go Michaelshortt???
Old 04-12-04, 07:45 AM
Been installing a new bath tub in my rental. Drained the gas removed the air filter. Need to look for the model number and order the parts. Thanks for asking terminator20, will let you know how it goes.
