Engine Running Problem
Old 04-18-04, 04:41 PM
chevyred55
John Deere Junk
Need help figuring out what is wrong this time. Nothing runs
like a deere if you can keep them running.
1999 GT 235 18 hr v-twin 181 hours. Seems to be sucking
oil into carb and will hardly run. Any ideas on this?
Something always wrong every time you need it.
Thanks for any help I can get.
Next mower will be Snapper or EXMark
Old 04-18-04, 10:52 PM
cheese's Avatar
Received 97 Votes on 90 Posts
Hello chevyred55!
What engine do you have? Could be a restricted air filter, bad pcv valve, rings, oil level too full, oil thinned with gas, etc...
Post engine info and check the oil level.
Old 04-20-04, 03:55 PM
puey61's Avatar
Received 2 Votes on 2 Posts
Any engine ID #'s yet? Based on the model of the tractor, you will have either a twin Briggs Vanguard or a single Kawasaki. Since you mentioned it was a twin, then the engine must be a Briggs. Being an authorized Briggs dealer, there are no known service issues with what you are experiencing, that I am aware of. Using cheese's advice, check these areas. Furthermore, ideally you should perform a leak-down test on each cylinder as well as a vacuum test on the crankcase if all of cheese's hints got you nowhere. The first thing that came to my mind was over-filled oil. How is the oil level?
