mower blades and gator blades
Old 04-18-04, 07:33 PM
errolw22
Question mower blades and gator blades
Hello every body my ? is about mower blades.i have a lot of oak trees in my yard about 1 acre.there for i have alot of bare spots who makes the best blades for cutting this.being theres alot of dirt that eats blades.Thanks for any help Errol McCullough
Old 04-18-04, 10:45 PM
cheese's Avatar
Hello Errol!
You live in my neck of the woods!
Look for an aftermarket blade called a "gator blade". They era made of thicker steel and last much longer. If you want to grow grass under those oak trees, lime the area. Get some pelletized lime from the store and broadcast it. The oak trees make the ground under them so acidic that grass cannot grow there. You'll have to do this yearly, but the lime is cheap.
Old 04-19-04, 08:34 AM
errolw22
mower blades
Hey thanks alot cheese how far are you from Brunswick GA.i have used gator blades b4 just hoping there was something better.i will try that lime under some these oak trees.
Old 04-19-04, 09:55 AM
puey61's Avatar
Gator blades
For an even heavier blade (thicker material) try Gator Magnum. These are products made by Oregon.
Old 04-23-04, 11:19 AM
errolw22
Thanks
Thanks cheese and phuey61 for your help.
Old 04-23-04, 11:24 AM
errolw22
Gator blades
Where can i get gator blades and magnum gator blades.Thanks
Old 04-23-04, 01:36 PM
Sharp Advice's Avatar
Admin Emeritus
Hi: Errol
The specialty blades wanted should be available at the local small engine sales and or repair shops and or lawn mower stores in your area.
Forum Monitors Note:
Threads merged (combined) to maintain continuity on the subject of blades.
Old 04-23-04, 03:44 PM
puey61's Avatar
"Gator" blades
"Gator" blades are a trademark of Oregon Outdoor Equipment. More commonly known for forestry products. Go to www.oregonoep.com and use their store locator for a location near you. If you were to provide me with machine specifics, I could give you the availability of a Gator Magnum for your mower.
Old 04-23-04, 06:41 PM
errolw22
mower blades
I have a husqvarna 1542xp the blades are 21inchs with a 5 star center hole.its a 42inch deck
