Eager-1 engine questions
Grandmaster's Avatar
04-18-04, 08:53 PM   #1
Grandmaster
Hi all,
Everyone was a great help with my last mower question...so I was hoping I could get some more help. I have a few questions about a Craftsmen mower with an Eager-1 6.75HP electric start motor. The other day when mowing with it, it blew something. I got around to taking it apart today and it was the head gasket that blew. The last few times that I used this mower I heard...well the best I can describe it as would be a rattle or a clank, like 2 peices of metal vibrating against each other. It only seemed to make the noise under a heavier load like cutting through taller grass. Not sure if this was related to the head gasket blowing or not...but I thought I would ask if anyone has exeperienced something like this and what it might have been. A couple of the head bolts did not seem very tight so I thought that might have been the reason for the clank. Any thoughts?
While I have the mower apart I thought I would also ask for some help on something that has always bothered me about the mower. It has always been tough to start after it has been sitting for a week or two. I usually have to press the primer bulb around 20 or so times to get the mower to start. But it always starts up and dies. Usually after about 5-10 itterations of priming and starting the engine will finally stay running. Is this normal for this type of engine on initial start-ups?
And my last question is I have had a hard time finding info on the Eager-1 engine. Is this engine made by Sears? Is it made by another company for Sears and if so who and can I get parts for this engine from the other company or am I stuck to getting parts from sears?
Thanks,
Louis
cheese's Avatar
GA
04-18-04, 10:40 PM   #2
Hello Louis!
The eager-1 engine is made by Tecumseh. It is just labeled Eager-1 for sears. If the noise you heard while it was running could be described as a metallic "chirping", then it was caused by compression leaking past the head gasket. The hard start issue is carburetor related. Remove the carb bowl screw. There are 4 holes in it. Make sure all of them are clean and clear. Especially the tiny one in the unthreaded end of the screw. It is hard to see.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
