Lawnmower not starting or staying started
I have a 13.5 hp yardman lawnmower that I can't get to start. The starter (which has just been replaced) will crank the engine, but the engine will not fire. It has gas, tried pulling the choke, checked the oil, replaced the spark plug, and the blade isn't engaged. If someone could help that would be appreciated.
God bless
God bless
Fuel may not be getting to the carb. Open the carb to see if fuel is running into the carb. If it is that you are getting fuel and there is most likely a restriction in the carb. If you see that it is getting fuel and no problem there, use Automotive Gumout spray to clean all the ins and outs of the carberator. Let us know how it goes.
Hello Justin!
Try putting a little squirt of gas into the spark plug hole and reinstall the plug. Then try to start it. If it starts and runs for a second, then dies, then you have a fuel related problem. If not, we need to look into other possibilities.
