B & S Numbers ?
Old 05-23-04, 06:50 PM
B & S Numbers ?
Have b&s motor, need info on it. model 130292, type 024901, other number , don't know if serial or not 76020406. Hp, what it is used on, settings. any & all info appreciated
Thanks T.J.
Old 05-23-04, 07:47 PM
Sharp Advice's Avatar
Admin Emeritus
Hello: T.J.
You should be able to find all the information wanted here:
Engine Codes: ...(Engine Manufacturer Web Sites Included)
http://forum.doityourself.com/showthread.php?t=68787
Briggs and Stratton Home Page:
http://www.briggsandstratton.com
http://www.briggsandstratton.com/dis...sp?DocID=64103
Briggs and Stratton Manuals:
http://shop.briggsandstratton.com/BS...ngineType=0436
http://shop.briggsandstratton.com/B...EngineType=0436
The resident small engine service and repair professionals in the forum may be able to offer additional suggestions, advice & help.
Check back on your question several times over the next few days for additional replies.
Small engine repair parts, generic repair manuals and additional help are all available at all local small engine repair shops and or lawn mower repair shops in your area. Shops and dealers are listed in the phone book directory.
If you need further assistance, use the reply button. Using the reply button moves the topic back up to the top of the daily topic list automatically & keeps all communications in this one thread.
Sharp Advice.
Master Small Engine Tech. Web Site Host, Forums Monitor and Multiple Topics Moderator. "Accurate Power Equipment Company." Engine Diagnostics Services & Repair. Fast......Fair......Friendly & Highly Proficient Services.......
Old 05-24-04, 03:19 AM
puey61's Avatar
B&S info
As a dealer, we have no way to know what equipment this engine was used on. Perhaps the factory might, but don't know this either. What I do know is you have a 1976 vintage, 5 horsepower, horizontal crankshaft, pulsa-jet carburetor, plain bearing, auxiliary drive (extended cam), rewind start engine. For the fact that it has an extended camshaft, I would say it was originally installed on a garden tiller.
Old 05-24-04, 04:36 PM
south
B&S Engine (16hp on Simplicity 6216)
I need a rebuild kit for the carb and noone seems to know what engine I have. Here is the number stamp on the engine.
402 07 0130 01 82042112
I refered to the B&S website for the style engine and found the location of the number. The guys at the small engine shop couldn't figure out what this number was...
Any help is appreciated...
Old 05-24-04, 07:25 PM
b&s numbers ?
Puey61 thank you very much for the info.
Now to the members of the forum ; If this motor is off a tiller. Could it fit on an older Ariens snowblower, 2 stage with 20" auger opening. Any major modifications, (ie) mounting holes, belt alignment, turn crank for the chute ,throttle cable, anything???. I WANT TO KEEP BLOWER IN ORIGINAL CONDITION !!!!Got blower without motor so am asking questions!
Thanking everyone in advance for info and answers.
Old 05-24-04, 10:59 PM
cheese's Avatar
South,
Was this # stamped on a silver tag on top of the engine? If so, look at the headings above the #s. You will see "model" over the first set of #s, "type" over the second, and "code" over the third. This would be all any shop would need for getting your parts.
Old 05-25-04, 04:13 AM
south
It was stamped on the front of the engine under a silver sticker. The sticker has engine oil info on it and on the bottom of the sticker it has Model, Type, and Code. The sticker is placed just above the numbers, however, I cant tell where Model ends and Type starts.
