Where can I pick up a tach
Old 05-23-04, 09:50 PM
P
I enjoy wrenching on small engines for myself, freinds and family.
The one thing I lack is a tach.
Can you direct me to where I can purchase a tach for small engines?
Thanks in advance,
Tom
Old 05-24-04, 03:21 AM
puey61's Avatar
Received 2 Upvotes on 2 Posts
Tach of what type
Are you looking for a mountable tachometer or one which you can use from engine to engine?
Old 05-24-04, 06:33 AM
P
puey61,
One I could use from engine to engine.
Old 05-24-04, 08:30 AM
puey61's Avatar
The least expensive would be a vibratory tachometer. Amazingly accurate and available through most small engine shops. Briggs, Tecumseh and Kohler all have them available. If you're looking for a digital tach, go with Kohler's - it's the least expensive. I'd go with the vibratory, if it were me.
Old 05-25-04, 05:49 AM
P
Thanks puey61,
Vibratory huh, that's new to me.
Could you explain how it works.
The tachs I've ued ran off the coil.
Sorry to be a pain.
Thanks again,
Tom
Old 05-25-04, 04:12 PM
puey61's Avatar
They work off of the vibration any given engine transmits to indicate, by means of a wire with a fluorescent colored tip that you move in and out of the tool. You twist the tach until you have a perfect circle at the wire end (the fluorescent colored part). The dial indicator on the tach then points to the RPM that you have. It works amazingly well. Tecumseh and Briggs each sell one (the exact same manufacturer, I'd say) but Tecumseh's is priced better...part number 670156, for around ten bucks. Try it, you'll like it!
Old 05-25-04, 04:26 PM
P
Too Cool!
But ya know you're creating a monster,, right? As he eye's the dogs wagging tail
Thanks puey61!
