IDC gas trimmer won't stay runnning
Ironworker470's Avatar
05-28-04, 04:01 AM   #1
Ironworker470
I have cleaned the filter in the gas tank and have also cleaned the carb.It will stay running for approx 20 minutes and then stall. When I attempt to re-start it will only run in idle,when I press the throttle it will stall out.
repair_guy's Avatar
New Member
AL
05-28-04, 07:25 AM   #2
You mite try opening the high speed ajustment screw a little(abuut 1/8 turn or so).the high speed is the one closest to the air filter.If that doesn't work your gona have to put a carb.kit in.
Otoe's Avatar
05-28-04, 11:07 AM   #3
Otoe
Gas Cap
Check the gas cap to see if it still vents the fuel tank. Or loosen
the cap and try starting it again. If it works, a plugged cap is
likely problem.
