kubota engine
Old 06-05-04, 09:59 AM
oscarnor
kubota engine
I have a Grasshopper mower model 725 with a three cylinder gas kubota engine no. WG750. From all indications the distributor has gone bad. I have put on a new coil, plugs, plug wires, and still can't get a spark. Whenever I turn the key off i get one spark. I am having a lot of trouble finding the distributor at a resonable price. Any suggestions. Oscar
Old 06-05-04, 11:53 PM
cheese's Avatar
Hello oscarnor!
I don't know where to find a distributor at any kind of bargain price. You might luck up on ebay if you keep an eye out. Check the distributor ground, if it has one. Does it have points or does it have a pickup sensor in the distributor?
Old 06-06-04, 06:30 AM
oscarnor
kubota engine
Hi Cheese, It has a sensor pickup. How would I test the distributor? Thanks for reply. Oscar
Old 06-07-04, 12:39 AM
cheese's Avatar
Do you have an analogue voltmeter? Does the pickup have 2 wires? If so, connect the voltmeter to the 2 leads (any polarity) and set the voltmeter to the lowest setting. Turn the distributor. If you see the meter needle jump back and forth a little while the distributor turns, then the pickup is working.
Old 06-07-04, 06:30 AM
oscarnor
I will try that. thanks
