4.5Q B&S Running Rough
Old 06-09-04, 11:36 AM
broken_mower
Hello,
I have a 4.5Q Briggs & Stratton mower that started running rough yesterday. It's almost sounds like it's running out of gas. Here is what I have done so far to try and fix it. I changed the spark plug {heavy carbon deposits}, removed cleaned and re oiled the air filter, removed cleaned and dried the gas tank and refilled with fresh higher octane gas {89}, cleaned the carb with gumout and visually inspected fuel pick up tube and screen, checked but did not change the oil, cleaned debris from the cooling fins and looked for obstructions or binding in all the linkages. I had the same running condition after doing these things. It ran perfect for about 5 seconds and then was out of gas, so I am assuming that the carb is somehow getting too much fuel. The engine has just under one season on it and has not been abused whatsoever. Any help on this would be greatly appreciated.
Model# 10G902
Type 0189B1
Code 03011054
Old 06-10-04, 01:15 AM
cheese's Avatar
Received 54 Votes on 49 Posts
Hello Broken mower!
Did you replace the carb diaphragm when you removed it? If not, you'll need to do so. This will probably solve the problem, but most anytime the carb is removed, it is best to install a new diaphragm.
Old 06-10-04, 03:20 AM
puey61's Avatar
The diaphragm cheese is referring to is Briggs part number 495770. Check with a local dealer for this item.
Old 06-10-04, 05:51 AM
broken_mower
Thanks for the info, I'll replace it today I hope. I'll let you know how it goes. I knew I should have taken that Foley - Belsaw course years ago!
Bob
Old 06-10-04, 08:37 AM
broken_mower
Talking
Thank you cheese and puey61. That was the problem. I never would have thought of replacing that part. This is a great forum, lots to learn in every post, thanks again.........................
Old 06-10-04, 09:51 PM
cheese's Avatar
Allright! Glad you got it fixed!
