Help With Lawnboy Silver Series
Old 06-09-04, 08:27 PM
TayWolf55
Hello,
You guys have got yourselves a newbie on your hands.
I have a Lawnboy Silver Series, Model Number 10247. Information can be found here about it.
http://www.lawnboy.com/productinfo/m...pro/10247.html
Anyways we were mowing the yard and heard a loud clunk, and the engine died. There was no tension what so ever in the line and called the Lawnboy tech service. They basically told us it threw a rod and this happened every once and a while.
We accepted that, and as a project I started taking it apart, seeing if I couldnt get down to the bare engine and get into it to see if I couldnt fix it.
Right now I've got everything off the mower except the engine and the blade, which I will do tomorrow. But basically here is my question.
Where can I go to get a new piston / rod assembly, or maybe just a new rod at? How much am I looking to spend for this? We called a local small engine service and they quoted us $200 + labor
That seemed a little outrageous so I was searching the internet and found this place
cliffnotes: think we threw a rod, where can we get a new piston / rod assembly for cheaper than $200 + labor
Thanks!
Taylor
Old 06-09-04, 09:13 PM
repair_guy's Avatar
New Member
Sounds to me that they quoted high because they didn't want to fool with it.Sadly to say,but some small engine shops do that.
Check your crancase good for holes, dings & dents and the base of cylinder for same,plus check cylinder for scars first.
Try Ashland small engines & parts.Their in Ashland,Mo. and sale after market (generic) parts which are cheaper than name brand parts are (in most cases much cheaper).The number is 1-800-828-0668.
Others will probaly have other places too.So check on your post often over the next few days.
GOOD LUCK!!!
Old 06-10-04, 08:43 AM
TayWolf55
thank you!
I will give them a call later!
