Unequal turning radius on garden tractor, why?
ChuckG's Avatar
06-11-04, 01:57 PM   #1
ChuckG
I have a 2002 Craftsman GT3000 graden tractor w/ a 48" deck. The turning radius to the left is roughly 3 1/2', the turning radius to the right is roughly 7'. The manual says that the front tires require a 1/8" toe to ensure proper turning. I have measured the toe and it appears correct. Why is my turning radius so dramatically different left-right?
Otoe's Avatar
06-11-04, 03:15 PM   #2
Otoe
Curb Adjustment
I'd suspect a bent steering rod. Ever crash into something while in a turn; like hitting a curb? I know this one from experience.
Otoe
puey61's Avatar
NY
06-11-04, 03:39 PM   #3
A model number would help us help you better. If yours for instance has two drag links (versus a drag link and tie rod combination) then one of these drag links likely is bent. If, however, you have the tie rod set up, then somehow the sector gear slipped a tooth, or more, in relation to the steering shaft gear. Let us know what model you have. It likely will begin with - 917.
ChuckG's Avatar
06-11-04, 06:44 PM   #4
ChuckG
The model number of the tractor in question is: 917-275023. As far as hitting anything; I have never hit anything, but the previous owner may have. There is no body damage, what can I look for in the way of structural damage?
Otoe's Avatar
06-12-04, 09:10 AM   #5
Otoe
A bent steering rod. The rod can be bent without any visible body damage.
fewalt's Avatar
VA
06-12-04, 11:26 AM   #6
Yep, my steering rod is bent and the turning radius, left/right is different.
Mine has been bent and straightened a number of times. Next time I'll place some type of close fitting pipe,as reinforcement, over the rod when I re-install it.
fred
puey61's Avatar
NY
06-15-04, 04:32 AM   #7
ChuckG,
You have a tie rod/drag link combination set up for your steering. Your steering wheel slips onto a steering shaft, which, at the other end is the shaft gear. This gear mates to a sector gear. It is here where you have trouble. Although this machine is only a couple years old, I have seen the bushings/bearings associated with this assembly wear prematurely which allows the gears to jump and cause the trouble you have. Look this over closely and repair as needed.
ChuckG's Avatar
06-15-04, 03:53 PM   #8
ChuckG
Unequeal turning radius
Puey,
Thank you for the information, your advice is always welcome.
Thanks again,
Chuck
