John Deere GT262 not charging
Hello,
our John Deere GT262 with the 17 HP Kawasaki engine FC540U(or V)202658,was fine then the battery light came on and shortly after it quit running,the battery is brand new and is not charging,we replaced the positive battery cable and cleaned all the connections.we have put it on the battery charger and can mow till the battery goes dead.what would be keeping it from charging?????the operators manual is no help !
Hello cadzillahh!
Have you checked voltage readings at the battery with a voltmeter? The charge wires come from under the engine shroud, and will read ac voltage until they go through the regulator/rectifier. This is an aluminum box shaped piece with fins on it. The voltage leaves that box as regulated dc voltage and goes to the battery. Check the terminals on the regulator, charging stator wires, and any connections in between. I seem to remember a connector with 4 or 5 wires between the stator and regulator that would make poor connection, get hot, and melt enough to cause complete loss of connection.
