Lawnmower problems
Lawnmower problems
I have a Snapper series 22 rear engine riding lawnmower, I have to set the brake to start it, when I release the brake the mower dies. Can anyone tell me where to start to fix this problem. I would like to disable the saftey equipment if possible.
Hello Ronald!
If it dies when you release the clutch/brake, then you have a problem with the seat switch. Check to be sure it is plugged in tight.
