craftsman 18" chainsaw won't idle
shane157's Avatar
07-08-04, 08:27 PM   #1
shane157
I have a craftsman 18" chainsaw (2.6 Cu in or 42 Cu cm displacement), it's a little difficult to start and you have to keep the throttle on while starting and atleast 1/4 throttle while running or it dies, it will not idle. Any help?
cheese's Avatar
GA
07-08-04, 10:01 PM   #2
Hello shane157!
You should have the throttle on when you start it. As for it not idling, check to be sure the air filter is not clogged. Also, check to see if the idle speed screw might have vibrated out a few turns. You could also have carburetor problems. Probably a rich mixture, caused by misadjusted mixture screws or internal carb problems.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
