Karcher 3000 problems (pressure washer)
Old 07-12-04, 05:07 PM
the gun has pressure but it spews water out of soap intake it is under pressure . Is there some kind of oneway vavle that has gone bad I have checked online manuel and pressurewasher parts.com to no avail.
Thanks in advance
Willc
Old 07-12-04, 10:18 PM
Azis
Not real up on pressure washers but the last one I worked on, the line for the soap attatched to a nipple which threaded in to the outled of the pump, it was a valve itself.
I also recall something about a soap tip? In order to use soap I think a certain tip is required possibly. It should have been included if so.
Couple things to check tho if no help give us some model #s so we can look for diagrams.
Old 07-13-04, 01:45 AM
cheese's Avatar
Hello Willc!
You will see that the soap nipple unscrews from the pump. Inside that nipple should be a spring and a check ball. This is what is not functioning properly. The spring could be rusted or distorted, or the ball could be rusted or stuck, or trash could be hung in it.
Let us know what you find!
Old 07-15-04, 06:52 PM
got it off and no spring or ball inside ? was it sussposed to de in the soap end of the nipple
Old 07-15-04, 09:55 PM
cheese's Avatar
Has someone had this part off before? Sounds like it has been removed and the parts either fell out or popped out and got lost. There has to be a check ball and spring in there for it to work. Is the pump# just 3000? Any other #s?
Old 07-16-04, 08:53 AM
Azis
The last diagram on this link, http://www.pressure-washer-parts.com/k_3000g_parts.asp
Maybe ball and spring are stuck in the outlet still, maybe a oring or plastic piece or something retaining it still????
