Alas, Another pressure washer question!
Old 07-24-04, 10:44 AM
Wilson
Hi Guys,
I have an Excell PW about 2 years old with about 4 hours of use on it. Two workers were using it and they said it just shut down with them. It has a 5 hp OHC Honda engine on it. When pulling the start cord it had no compression on it. I removed the valve cover and the Plastic cam shaft pulley was shattered. Everything else seems ok.
What would cause the pulley to fail? And asummng all else is ok, when I replace the pulley how do i reset the timing?
Old 07-25-04, 02:16 AM
cheese's Avatar
Hello Wilson!
What model# engine do you have? It has an overhead cam?
Old 07-25-04, 02:28 PM
Wilson
Model #
Hi Cheese,
Yes it has an overhead cam, and the model I'm not sure of right now. I will have to get the complete # at work tomorrow. A partial # is GC160 something, I will post complete # tomorrow.
Thanks
Old 07-26-04, 05:12 PM
Wilson
Honda Engine 5HP Model GC 160 QHA - OHC- Needs timeing set?
Got it put back together today after 4 months of not having "TIME" , finally got a spark at the plug.
It started 2nd pull, it ran rather rough though. Sounds like the carb needs adjusted but I have everything back as when it was running good. It started 2nd pull. I'm not sure about how to set the timing. Any advice on how to time properly?
Thanks,
Wilson
Its on a 2400 PSI Excell Pressure washer, I started it with out the pump on, would that make it run different?
Old 07-26-04, 10:51 PM
cheese's Avatar
Are you wanting to set ignition timing, or valve timing? If it is surging, it will probably quit doing it when the pump is installed.
Old 08-21-04, 12:19 PM
Wilson
Like New again
Thanks Cheese for your help. I found a company in Wisconsin that faxed me the procedure for setting the timing. I also found the breather button had broken and fallen out. Replaced the breather and it runs like new again!
Thanks again,
Wilson
