07-28-04, 06:08 PM
cajunhockey
Karcher K2400HH pump issues
I have read through the threads and they have been helpful with my problem on the Karcher K2400HH Power Washer. Issues with no pressure unless I remove tip and let straight water flow first. Problem now is that i removed the pump and the pump fluid came out from the piston area. Wondering first what to replace fluid with (type). Still can not remove the Spill Valve but I have ran Vinegar through water path. Hoping that once I re-fill piston / pump area things will be working better. Any advise you can give would be appreciated.
Cheers.
Cheers.
07-30-04, 01:49 PM
cajunhockey
Cheese, thanks a million. Washer is working well now. Getting to the Spill Valve is a pain but thankfully a good cleaning does the trick. Your advise within another thread concerning Karcher helped out more than you know. I owe you a pint someday.
Cheers.
Cheers.
