Briggs & Stratton Mower Help
mowmow's Avatar
07-31-04, 11:51 AM   #1
mowmow
Murray/Briggs & Stratton Mower Dies
We have a Murray push mower with a Briggs & Stratton motor. It is a Quantum Power, 5HP, Model# 12F702, Type 0714-01, Code 96101559. It has a primer. I ran out of gas while mowing yesterday. I filled the tank with new (week old) gas. It started right up and then idled down and died. It wouldn't immediately start back up. I let it sit for 10 mins and tried it again. It started right up and immediatelyl died down and out. I pulled the line off where it comes out of the gas tank and gas flowed freely. I removed the air filter holder to get to the other end of the line where it goes into the round thing with a flap inside (carb?). The line is clear. I do the yearly tune-up but do not otherwise know much about motors. I would really like to fix this myself and save money. Can you help me?
Thanks,
Lynn
cheese's Avatar
GA
08-01-04, 07:51 PM   #2
Hello Lynn!
Sounds like you need to remove the bowl on the bottom of the carburetor and clean it out. You probably picked up a bit of trash or water (usually goes into the carb with the very last of the gas in the tank).
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
puey61's Avatar
NY
08-02-04, 03:16 PM   #3
Be sure to check and clean the bowl nut/main jet for any trash as well. Tiny holes here...look closely.
