Yard -Man vibration problem
Old 08-03-04, 05:54 PM
billkc
Ok first off my mowers info
its a MTD Yard-Man model No. 12A-559K401
with a Briggs & Sratton model 120602 Type 0131 motor
Heres my problem,
While mowing I hit a rock that had been thrown into my yard and it killed the engine.
I could visually see that the blade had been bent so I replaced it with a new blade. Ever since then the mower vibrates violently while running. I checked all the bolts to the blade as well as the bolts fastening the engine to the deck , all are tight.
So I'mnot sure whats causing the vibration. Could it be a bent shaft? if so can I replace it or is my mower toast?
Any thoughts on what I need would be appreciated
Thanks,
Old 08-03-04, 09:44 PM
Azis
Remove the blade again and make sure that all dirt grass and any debris are clear from where it mounts to the hub and the washer...the bolt may be tight but could be some debris under the washer or mounting surface.
If not the case post back and we continue
Old 08-03-04, 09:47 PM
sounds like you got a bent crankshaft. i just got one staightened out . it cost 35.oo. it has to go on a special machine. my brother in law hit a water main.
Old 08-04-04, 07:12 PM
cheese's Avatar
Agreed, bent crankshaft. Replacement reccomended, but some people straighten them. (I have done both with good results).
