John Deere Lawn tractor won't crank
John Stafford's Avatar
08-07-04, 12:54 PM   #1
John Stafford
Any suggestions? Since one and a half weeks ago my John Deere STX38 lawn tractor wouldn't crank any more. It's about 14 years old, had regular maintenance through our local small engine John Deere dealer, including this spring. The battery shows 12 volts. The engine won't turn over when I turn the ignition switch. The gas line shutoff is turned "on". The product identification number is MOOSTXBO35602. The fuse near the ignition switch is good (I used the ohmmeter). I could buy a replacement ignition switch, but I don't have a schematic to check the connections. Anything else I can check? Thanks.
Azis's Avatar
08-08-04, 12:40 AM   #2
Azis
Have a look at this thread, http://forum.doityourself.com/showthread.php?t=175545
Should give you some ideas to start, basically begin at the starter and work back toward the key switch.
Post back if that helped or not.
puey61's Avatar
NY
08-10-04, 02:50 PM   #3
John,
Any luck on the no-crank problem yet?
08-16-04, 08:47 PM   #4
John Stafford
Wrong Voltage
Well, I remembered the wrong voltage when I posted my original message. I really measured 6 volts, not 12. It was a closed battery. It must have lost half of it's cells suddenly, and didn't even click the solenoid. Anyway, replacing the battery fixed the problem. Thanks alot!
