murray 22" push mower problem
I have a 22"side discharged mower, it starts an dies , it seems like it's not getting fuel , could carb be dirtyinside the mower is little over 3years old. It
was hard to start then now it starts and dies? any help.
arty101
arty101
Received 2 Upvotes
A starts & stalls condition won't have anything to do with the spark plug, but by all means, if it's original replace it. You will have a carburetor related problem though. Remove it and clean thoroughly using a kit for whichever particular engine you have. If you supply the engine ID #'s, I'll give you the part number(s) you'll need. You'll just have to go to your local repair shop and purchase the parts.
murray22" mower
Originally Posted by sceptre
try changing the sparkplug, if that does'nt work remove the carb and clean
completely paying close attention to the brass bowl bolt. make sure the two
intersecting passages are clean.
the bolt on the fuel bowl and drain it, clean manifold .an plug , it runs fine
thank you for everybodys help. arty101
