Shindaiwa B45, runs in choke only
Old 08-13-04, 06:24 PM
maulrat
Hello. I own a Shindaiwa B45 brushcutter with a 2-cycle engine. Was working fine till I let a friend borrow it. Now it only runs in full choke only. I changed the spark plug and still same symptoms.
Takes forever to start
When started, only runs with full-choke, but trimmer wheel is partially moving.
When running, it dies out if: i open choke at all or if i give it some gas/throtle lever. It also dies out, when I back off the idle adjustment screw.
No black smoke comes out of exhaust and there is no visible signs of fuel leaks
Any ideas would be greatly appreciated
Thanks =)
Maulrat
Old 08-15-04, 01:49 AM
cheese's Avatar
Hello Maulrat!
Sounds like you have a restriction in the carb, or a cracked fuel line. Check the lines, if no problems found, cleaning the carb should do the trick.
