weedeater 18cc carb trouble
Old 08-14-04, 04:30 PM
keagle
Question weedeater 18cc carb trouble
When I push the priming bulb in, it stays in....Replaced hoses and filter...no luck. Cleaned carb, ran great for 2 starts. Took carb apart again, blew out holes, cleaned screen, (wasn't dirty that I could see) put together. Pressed primer bulb, worked fine. Hooked up fuel line. Won't suck up fuel. Any help? Thanks...
Old 08-15-04, 01:33 AM
cheese's Avatar
Hello keagle!
Any chance you crossed the fuel lines when you reassembled it? Check the primer bulb for cracks/holes.
Old 08-15-04, 03:01 AM
keagle
didn't cross fuel line...cleaned what I could see...what else? New weed wacker?
Old 08-15-04, 08:18 PM
cheese's Avatar
Can you get fuel to flow through the line while disconnected from the carb? If so, then you still have problems in the carb. Did you install a rebuild kit when you had it apart?
Old 08-16-04, 05:02 AM
keagle
lines and filter work fine. Fuel just won't go into carb. I can squirt cleaning fluid through carb inlet. When fuel line is hooked back up...it won't go into carb....
Old 08-21-04, 11:32 AM
keagle
problem fixed
Feel like a BIG DUMMY! Rebuilt carb,replaced fuel lines,filter, all for no reason...
found a "microscopic" pinhole in primer bulb. Too small to really see, but big enough to cause problem. Thanks for all the help.
Old 08-21-04, 01:20 PM
cheese's Avatar
Lol, the small holes are easy to miss. Glad you got it fixed!
