generator won't start
dlsmith's Avatar
08-21-04, 03:19 PM   #1
dlsmith
I have a Generac SE5000 generator with a Briggs & Stratton engine(model 185432 type 0606). I last used it about a year ago and drained the fuel when I put it away. Since hurricane season is here I tried to start the generator to make sure everything was ok. The rope would not pull very far. When I removed the rope and turned the shaft by hand it would not turn 360 degrees. It stopped at the same spot no matter which way I turned the shaft. What could be causing this problem?
Thanks in advance for any advice!
cheese's Avatar
GA
08-24-04, 12:14 AM   #2
Hello dlsmith!
Sounds to me like you have a stuck valve. Happens often on engines that are stored for long periods of time.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
