rough running
rogerhrt's Avatar
08-23-04, 10:57 AM   #1
rogerhrt
rough running
Well i put in new points and condenser and cleaned everything up on this 2 horse. b and s engine which didnt run atall before that . Now she runs real rough and no idle and backfireing. Is that carb. problem?
Thanks for your advice,
Roger
P.S. (model#60102 type#0426-01)
puey61's Avatar
NY
08-23-04, 02:36 PM   #2
Sounds like ignition trouble. This engine has points & condensor as well as an ignition coil. If it were mine, I'd do away with the points & condensor by way of replacing the old coil with a new solid state coil. The new coil fits up exactly the same way as the old. You can but don't necessarily have to remove the points & condensor, although I recommend this. The Briggs part number is 496914 which includes an instruction sheet to do the job and sells for around $32.
